macro for pixeltrack pro 20ch Topic is solved
wesley2004
Post by wesley2004 »
does anybody has te macro files for the pixeltrack pro (20ch).
I rent these pixeltracks for thursday and started to preview them in freestyler.
There ar no macros and other things for it so maybe somebody have them?
FreeStyler Version: N/A
Re: macro for pixeltrack pro 20ch
Post by remco_k »
What macro's and other things do you mean?
If that fixture runs in 20ch mode, it has no macros and other things (whatever that is :D ) it just has 20 RGBS channels, thats it.
You can create macro's for yourself and re-submit the fixture file here: http://www.freestylersupport.com/fsforu ... =61&t=1085
wesley2004
what i mean is things like standard color changes and stuff like that!
But i think i have to make it myself?
Bedankt vast voor de hulp :)
Post by remco_k »
wesley2004 wrote:what i mean is things like standard color changes and stuff like that!
Geen dank. :D
You need to create sequences by yourself, always, as sequences are programmed for specific DMX channels you use.
You could interchange sequences between different users, but only if they use the same DMX channels for each pixeltrack.
Used them a lot but can't find sequences I created in the past; see movie here: http://www.freestylersupport.com/fsforu ... =13&t=1289
Among others I used 4 pixeltracks @20ch mode - created things like VU-meters and stuff. They can be seen in the movie I posted in the above linked topic.
