Futurelight PHS-260 Topic is solved
bezo16
Futurelight PHS-260
Post by bezo16 »
Please.. I need your help. I need fixture for moving heads Futurelight PHS-260.Please
FreeStyler Version: N/A
Re: Futurelight PHS-260
Post by remco_k »
Moved to "Fixture requests" - this topic does'nt belong to "Help & Support"
And if (only if) you want to have a better chance someone creating it for you, at least supply the manual and/or DMX channel description.
Or better yet: just start the fixture creator yourself and have a go. With basic DMX knowledge and some common sense, you are able to create the fixture file yourself. For a starter finding out the first time: within an hour you have the basics running.
Wupgup
Post by Wupgup »
Finally registered after at least one year reading :).
I've made the fixture for freestyler about a year ago, and it was working ok except for the macro's if I remember correctly.
You can find the file over here: <removed, no external links, see below>
edit: right click --> save as
Reason: Removed external link to unsupported fxt file
Post by remco_k »
Hi, welcome to the FS forum.
Please don't link to external websites, as we can't guarantee they will be online in the future.
Also, fixture files need to be exported using the export function in the fixture creator. (it creates a *.pff file). You should use that - that file contains all images and other stuff needed.
I have removed your link to the fxt file, but for conveniance I've converted it to a pff file and attached it here:
PHS-260.pff
(41.15 KiB) Downloaded 320 times
