Equinox Sigma laser/ Acme dynatwin Topic is solved
dave23
Post by dave23 »
Hi I'm trying to create files for these 2 fixtures but cant get my head round how to do it any advise or files would be most appreciated.
I have attached the user manuals below.
Thanks Dave
DYNA02-um0.pdf
Dynatwin
(294 KiB) Downloaded 119 times
EQLA09-um0.pdf
Sigma
(1.86 MiB) Downloaded 94 times
Pmarten8
Re: Equinox Sigma laser/ Acme dynatwin
Post by Pmarten8 »
Your Dynotwin Manual is terrible and unusable you cannot read channel values
Can you please wright the channel description and values down here and i can check this beta version i have made
Here test it there maybe problems with this but if you can post that information i can check and fix any problems thanks
Dynotwin-Beta-v1.0.0.pff
(56.22 KiB) Downloaded 83 times
gareth3939
Post by gareth3939 »
hi, thank you for your beta fixture for the dynatwin 100W been looking for it last few days then some how i found it on a google search as i didn't see this on the main page for fixtures, ive installed it but only the left mirror is working and being controlled.. gabos working fine, on and off light is fine and strobe is also fine! and pan and tilt but only on left side not sure if gabo is moving for the 2nd mirror as i can see 2 sets of gabos to control and i guess the 2nd one is for the 2nd mirror...
i am new to this but learning fast ! i was about to attempted to make my own fixture but lucky i came across this! i been using another fixture to control the dynatwin so far but had to use 2 of the same fixture but i wasn't getting proper gabo control and strobe and light open was wrong way round! so im now glad to find your beta as i may be able to edit it my self abit easier
if i make any improvements i will let u know but im not keeping my hopes up lol! but thought i let u know as i may just have a setting wrong maybe??
Thanks in advance!
gareth3939
ive edited it to 4 channels now and add the fixture twice and now i got full control of each side :)
i dunno if this is ment to be the right way to do it but least i got all the gabo controls and lamp on and strobe etc all right now :)
i just need to find a fixture for my acme leo 250W MH-630 lol
