Hello
I have one suggestion about DMX400.
I think is good idea to add buttons do DMX400 to control color fixtures in DMX400.
Maybe 7 buttons with color : RED, BLUE, GREEN, CYAN, MAGENTA, YELLOW, WHITE or maybe add programmable buttons to programing their color.
What are You think about it ?
Jakub
DMX400 Color Buttons Topic is solved
garyee
- FreeStyler Version: 3.3.2
Re: DMX400 Color Buttons
yeah !!
- DMX 400 is a good tool but it would be even better if the user could choose the colour (fg,bg).
Maybe with the color chooser-tool (wich should support RGB+A/W
) to choose a serie of colours wich is goging to be blend in.
- To split up the speed in fadetime and scene-time (like for the cue's) would be helpfull, so you can controll if you want to fade the light over or have more of a blink-over. (I kown there is a fade option but it isnt enough)
there is such much potential for developing in the DMX 400 ...
gremlins4x
- FreeStyler Version: 3637
I managed to create an ssl2 file for this product. Maybe I'll help someone.
Led Wash Zoom 36x12w.ssl2- (13.81 KiB) Downloaded 90 times
