I have created a number of sequences using the 10 pinspots i have setup. I tell the pinspots to 'use in DMX400'. If i go into DMX400 they work fine. After shutting down dmx400 the sequences no longer work in 'submasters.' I am guessing the fixtures are locked out and I need to release them?
Also, I cannot get the pinspots to work in Sound 2 Light. I have told them to react to sound. I have tried it with DMX400 running and not running.
I have the latest Freestyler and S2L.
Any help would be very much appreciated.
return control to submaster after DMX400 + S2L wont control
gherd
- FreeStyler Version: 2.96j
gherd
Re: return control to submaster after DMX400 + S2L wont cont
I was able to solve my issues. I created a new fixture, 3 channel and defined it as RGB. I set the address to that of my dimmer pack and now it works fine in DMX400 plus sound to light.
