Sunstrip
tufolu
- FreeStyler Version: 3.4.6
- Twitter: https://privateladyescorts.com
Sunstrip
How to use the FX editor in sequence creator with only one fixture? I want to make my personal chase with a sunstrip for use them in submaster....The FX creator want more than one fixture...
secure adult chat - https://privateladyescorts.com - private lady chat online
Re: Sunstrip
you can't. The fixture file only has attributtes for one segment (intensity channel, RGB etc). therefor FS don't know that the sunstrip has more segments. you have to split your sunstrip into servereal fixtures, where each fixture controls the RGB channels for each segment.. Then FS knows you have more fixtures (segments) selected and can generate FX'stufolu wrote:How to use the FX editor in sequence creator with only one fixture? I want to make my personal chase with a sunstrip for use them in submaster....The FX creator want more than one fixture...
tufolu
Re: Sunstrip
I'm going to add 20 par56...thanks for this rapid re-post
