Chauvet Colorband Tri Topic is solved
Pmarten8
Re: Chauvet Colorband Tri
Which fixture Mode do you need there our several different set-ups
36CH Mode
18CH Mode
12CH Mode
9CH Mode
6CH mode
4CH Mode
3CH mode
7CH Mode
I can make this for you but will need more info first
36CH Mode
18CH Mode
12CH Mode
9CH Mode
6CH mode
4CH Mode
3CH mode
7CH Mode
gw99
36-ch mode although im not sure freestyler supports this?, so I can do more with the colors..
Thanks so much!
Thanks so much!
Pmarten8
Hi GW
I'm afraid freestyler dose not support this fixture just yet i have tried to get this built but have hit brick wall as cannot even build it in 7 channel mode because you need more then 1 channel of RBG which at the moment is not possible i have requested few updates be done to fixture creator to allow these new types of fixtures to be built as fixture creator is now finding quite a few limitations as new fixtures have different configurations and require two or more of the same type of channel channels eg: RGB, Tilt/Pan, Shutter, Strobe, Prism,Irises and focus
Your fixture in 36ch mode needs just 12 RBG = 36CH
And this cannot be done just yet fingers crossed fixture creator will be updated soon as soon as it dose i will get this created and PM you
Thanks Again
Thanks Again
Pmarten8
Final Thought
If this is the only fixture you want to control with freestyler you can build 12 fixtures address them to the same address and you would be able to do it but i don't support building fixtures this way as i don't think it looks very professional and for sure its pain in backside to control a fixture this way
Look forward to helping you again soon
Ryan0751
I just ran into this as well... I have 8 bolorband tri's I'm planning controlling with Freestyler. Couldn't I just create one fixture the is just RGB... then just created 12 of them per strip in Freestyler? It'll wind up looking like 96 fixtures unfortunately but I think it should work?
Mavi
It will work, if you do the addressing right!
I do not know what you want to do exactly with these fixtures, but perhaps you should look at the LED-Trix plugin as well.
Ryan0751
Yes, I have set them up in LED-trix. I would like to do some basic color fades as well, the entire thing at once. Rather then setup a bazillion fixtures, I did this using Luminair for now on my iPad.
