Chuavet Q Spot 260 LED
DRMADD
Post by DRMADD »
Make sure your fixture is in ADVANCED mode. It will NOT work properly in BASIC mode.
Enjoy :fs:
Q-Spot 260 LED.pff
(159.02 KiB) Downloaded 162 times
Reason: bracket place corrected
DELighting
Re: Chuavet Q Spot 260 LED
Post by DELighting »
How can I edit the Qspot 260 LED for the Easy View 3D? It doesn't have the gobos in the profile and I can't figure a way to put the correct ones in.
DRMADD
Post by DRMADD »
Wish I could help but my capabilities are limited to fixture creator. I don't use easy view enough. Sorry ;(
Return to “Chauvet”
