I need the fixture of the Contest Razor-tri , create the fixture is impossible , the manual is poor in informations !
Thanxs a lot
Bonsoir,
Quelqu'un aurait-il la fixture freestyler pour le contest Razor-tri , creer une fixture est impossible , le manuel est trop pauvre en informations .
Merci beaucoup !
Request Fixture : Laser Contest Razor-tri
Oriambre
- FreeStyler Version: 3.2.1
Mavi
- LJ
- FreeStyler Version: 3.2.8
Re: Request Fixture : Laser Contest Razor-tri
If you have the manual (and at last the fixture at your side) and we do not have it it will be much harder for us to create a fixture or help you.
What you can do easily if the manual is that bad:
1.) create a simple fixture with the number of channels you have and the information you get from the manual
2.) use the sliders from this simple fixture in FreeStyler to controll the laser and find out wich channels have wich function and wich values are good for your use
3.) improve the fixture file with the information you gained from playing around with the simple fixture file and (if you want) create macros for the values you found out
4.) do not forget to upload the completed and improved fixture file to the user created fixtures section in this forum so that other people can use your file if the get the same laser
If you need more help please feel free to ask again. But provide more information like the manual and the partial fixture file (if you have one).
