First have you tried? Log in to Search the Forum for help! Learn more about using FreeStyler at the FreeStyler WIKI HERE
it would be nice if you make a position and if you have also activate a pan and/or tilt cue that the fixure will pan and/or tilt on the position you have activated.
postion Example:
IIII
XX
IXI
Disco ball
roof
and if you activate the Pan and/or tilt cue it will Pan and/or tilt on the postion you have activated.
would be a nice Feature. and you can also use them without a pan and/or tilt. (pallets )
Greats Emile Ballard
You can set up different positions by using the override buttons. I set up some positions on every new setup (mobile lightning) and put them to some override buttons. Then I can activate them by hitting the keybord shortcuts for the coresponding override buttons directly.
