Hello,
When I override a sequence using the override buttons, the little blue pyramid with the exclamation point appears on the selected fixtures, but "Release All" does not appear to release the fixtures.
Is this the correct behavior? Does Release All only release fixtures that have been manually changed and not changed via the override buttons?
Thanks,
Doug
Release All Button does not work Topic is solved
- dmxlighting
- FreeStyler Version: beta
Re: Release All Button does not work
Thats correct Doug. Overide buttons will to total priority over everything. It will bring the cveride triangle up on the relevant fixtures but the release all button will stay greyed out and have no affect at all.
So its not a bug this time.
