Showtec Shogun DJ G-100 7ch.
6h5c
FreeStyler Version: 3.6.2
I Use FreeStyler for: Band
Post by 6h5c »
Here's the fixture for the Shogun DJ G-100 laser (art. 32001). I believe the DJ G-40 (art. 32000) is the same, only lower output, so this fixture can be used for that model as well.
Showtec Shogun DJ G-100.pff
(16.96 KiB) Downloaded 171 times
6h5c
Re: Showtec Shogun DJ G-100 7ch.
Post by 6h5c »
And here are the chase files for ALL the patterns this laser can do. Some descriptions are in dutch, but you'll figure it out :-). The fixture must be configured to DMX address 1 to 7.
Enjoy!
Ray
Shogun DJ G-100 chases.zip
(25.19 KiB) Downloaded 154 times
thank you, you help me out last weekend it isn't realy a good fixture file but it is allways handy to now which channel does certain thinks.
but i use'd the G-40 version but it works also with this fixture file.
thanks a lot.
6h5c
Post by 6h5c »
It's a simple fixture indeed, no fancy gobo for each effect. But there are >100 in it, so it would be a hell of a job to sort them all out :)
Did you use my chases as well? There's one for every effect, so that would save you a lot of work. It took me a few hours to sort them out :lol:
Ray
No i did not used then. BUT IT's REALY STUPIT from me i just saw it totday but not that night :(
and a nother stupit thin is that night i also used 2x G40 ch1-7 and my owne laser ch 100 or something.
and a dutch manual I don't mind, ben zelf nederlands. ;)
6h5c
Post by 6h5c »
Ok, misschien de volgende keer dan :)
yes maby next time i think i will see this Laser a lot more.
Return to “Showtec”
