auto change on cue list buttons
dmxlighting
FreeStyler Version: beta
Post by dmxlighting »
If you ue fs for disco type work and you are working alone then your limited to what you can do as to contolling your lighting. I have seen that many guys leave the lights on one cue and dont really change it much if at all.
My idea is to have a way of auto changing the cue list buttons ina 'loop x number of times' then chane to the next one and so on.
Any aditional thoughts ?
Android Dev (Moderator)
FreeStyler Version: BETA
Re: auto change on cue list buttons
Post by Mattotone »
yeah its a good idea, iv been using a modified version of the goMonkey to do just that. but would be much easier if built into FS
6h5c
FreeStyler Version: 3.6.2
I Use FreeStyler for: Band
Post by 6h5c »
One more vote from me for this feature!
I have created several sequences for my PAR's, and 'loop all sequences' only runs each sequence once. It would be great if a number could be entered to specify how many times you'd like a sequence to run before it skips to the next one.
Maybe the 'scheduler time' field can be used for this? It's already there, and a two- or three digit decimal number entered here, instead of a HH:mm:ss time format, could easily be interpreted as the so-called 'run-multiplier'.
Regards,
Ray
j141
Post by j141 »
Another vote for this :)
Return to “Ideas and Remarks”
