Fixture on key Topic is solved
tofmx
Fixture on key
Post by tofmx »
Hello !
Sorry for my English ...
I try to assign a fixture by key on my keyboard. How can we do?
Thanks.
Shannon D
Re: Fixture on key
Post by Shannon D »
Are just trying to select a fixture? We need more info to help you.
Re: Fixture on key
Post by LJ_krede.dk »
you can assign fixture groups to keyboard shortcuts. if you only want to select one fixture from a keybaord shortcut you just add one fixture to a fixture group.
1) Select Edit-->Groups
2) Add groups by write a name and hit "Add Group". (in this example I have chosen "Group [X]" where X is 1-3)
Group Window.png (2.34 KiB) Viewed 274 times
3)Select the fixture you want add to a group and select the group. then press "Add fixtures"
add fixtures.png (6.98 KiB) Viewed 274 times
4)to assign a fixture group to a keyboard short cut go to Setup --> FreeStyler Setup
5)in the setuo window choose External Control --> Keyboard shortcuts and scroll down to "Groups [X]", selct the wanted group and press the desired key on keyboard you want as shortcut key.
(8.77 KiB) Downloaded 1 time
Now you have keyboard shortcuts for your groups/fixtures.. to deselect a group/fixtures you have to press the shortcut key again.
tofmx
Re: Fixture on key
Post by tofmx »
ok.
Yes, I want to light on one fixture (scanner or flower,...)with a key assigned on the keyboard.
Thanks for helping.
