hello,
Is it possible to create a device for the Jb Systems Club Laser7 Mk2?
I have tried but given the number of gobo in this product, I can not easily use this device.
thank you for your help
- FreeStyler Version: 3.3.2
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: Jb Systems Club Laser7 Mk2
Freestyler currently doesn't have any laser layouts.
It's more than likely that any fixture made for you will suffer the same usability issues.
Lasers can be quite complex devices of which dmx isn't the best to control it, the larger lasers use ilda and dedicated software.
