Need help with Fixture creator - Pre-programmed shows
Locked
blaide13
Commited FS Forum helper
FreeStyler Version: 3.0.1
Post by blaide13 »
I have a light which is essentially the American DJ Mega Panel, an RGB panel. In 7 ch DMX mode, channel 4 in the fixture manual is p-re-programmed shows and channel 5 is the speed. I successfully created a fixture profile in fixture creator, but don't know where to put Ch 4 and Ch5. I tried putting them in the pan tilt section, but then they are on all the time. I'm thinking I can place them in the macros, but have no idea if that's possible or how to do it. Is there a Macros tutorial? I havn't been able to find one yet.
just for additional information, I only need to find a place to place Ch 4 and 5 that are easy to control and can be turned on and off when I want to switch between RGB mode or preprogrammed shows. Channel 5 controls the speed of the shows. Here is the channel listings for this fixture in 7 channel mode:
CH1 - Red
CH2 - Green
CH3 - Blue
CH4 - 001-239 Color Show
240-255 Sound Active
CH5 - Speed Adjusted
0-100%
CH6 - Strobe
CH7 - Master Dimmer
0-100%
All channels have been succesfully created in fixture creator except CH 4 & 5. Any suggestions?
FreeStyler Version: 3.3.7
Re: Need help with Fixture creator - Pre-programmed shows
Post by LJ_krede.dk »
This is a exact copy of your other post.. Please don't make double posts.
This topics is now locked. go to the other topic to discus this matter
with that said,, i'm at work right know but I will try to help you if I get some time off this week.
/LJ_krede.dk
Aalborg, Denmark
Locked
