Are you limited to the list of cues in the cue box or can you add more?
Thanks.
More Cues? Topic is solved
- dmxlighting
- FreeStyler Version: beta
Re: More Cues?
In theroy you can have an unlimited number of cue pages, each cue page can have a max of 20 cues.
Once you have loaded some cues into a page you can save this, then clear the page a start again.
As my mini war with DJsupport is now over I will probably upload an updated guide to using the cues and submasters in the near future. For now the original version is avalible on the fs wiki. This might help too.
mattjake4
Re: More Cues?
Gotcha.
Freestyler timecode works really well. I'm liking freestyler more and more everyday.
My next step would be midi control.
Any recommendations for a midi control console especially for freestyler. It would be nice to set faders for conventional lighting.
- dmxlighting
Re: More Cues?
the best midi controller for fs is the bcf2000 and lots of us on here use it so there is lot of support for it.
Its not badly priced either. Others on here like the much cheaper Korg stuff but BCF in my humble opinion is far better.
Reason: Misspelling corrected
mattjake4
Re: More Cues?
Hmm. So you know in the cue list how you have to click the play simbol to play the cue, is there a way to assign that to the midi board?
- dmxlighting
Re: More Cues?
Not sure about the 'play buttons' being assigned to midi but if you learn to use the submasters then you wont need that and you will find fs is far far better to use. See my tutorial on the FS wiki.
Several 1000 users cant be wrong!
Re: More Cues?
1) go to External Control --> Midi control in the setup windowmattjake4 wrote:Hmm. So you know in the cue list how you have to click the play simbol to play the cue, is there a way to assign that to the midi board?
2) assign MIDI notes to "Sequence [X]" where X is the sequence number 1-20 in the cue window
