irock 7b fixture needed or help creating
leedaddy
FreeStyler Version: 3
Post by leedaddy »
hi
iam new to dmx and fs i have recently downloaded the software and got me an enttec dongle
most of the lights i have does have fixtures except for the i solutions irock 7b , their is a fixture which works with it sc250 but its limited as the irock 7b has much more features than that fixture
if someone has the fixture created or advise on how to create it please let me know
Mavi
LJ
FreeStyler Version: 3.2.8
Re: irock 7b fixture needed or help creating
Post by Mavi »
If you have a fixture file working for some parts it may be a good thing to use that file and build the new features in. Otherwise you can start with a new fixture file. You can use the Fixture Creator to set up new files or open/edit existing ones. How to work with fixture creator can be found in the wiki: http://www.freestylersupport.com/wiki/fixture_creator
When you got a fixture file with the function you need feel free to share it in the user created fixture files download section.
If you run into any trouble creating the fixture feel free to ask again with the specific problem. Describe what you want to do and give the manual with the DMX channel discription and the fixture file you created so far to us. But at the point I can only tell you to read the wiki-post I told you.
