american dj tripleflex Topic is solved
dancewave
Post by dancewave »
i was hoping someone would be able to help me with this fixture as i have not yet been able to get it to work for me
thanks for any help i get in advance
kunerd
Re: american dj tripleflex
Post by kunerd »
Has anyone been able to create one for the Triple Flex yet? I am unable to with the 3 separate mirrors. Any help would be great!
Post by LJ_krede.dk »
I assume you have tried to make file since you write "unable to"... do you have the fixture file for your try. If yes, upload it,, then i'm sure someone will have a look and help you out.
Fixture file for 4 channel mode should be straightforward bacause all mirrors do the same and thereby the fixture file is like one for a regular fixture. use macros for the movement functions
regarding 9 channel mode maybe it would be best to make 1 fixture file:
channel 1: Mirror
channel 2: Colors
channel 3: Strobe
you can make macros for the colors and/other thing if you want.. it makes it easier and quicker to program the fixture
if you then have the fixure on channel 1, you add the fixture file 3 time into FS
fixture 1 (mirror 1): channel 1
fixture 2 (mirror 2): channel 4
fixture 3 (mirror 3): channel 7
Post by Jan_K »
Hej Folks.
Was to busy on the wiki so I forgot to upload this http://www.freestylersupport.com/wiki/f ... ter_effect
Fixture for the 4 and 9 channel mode are there but they are not tested.
Please give a feed back if they work. :)
Jan_K wrote:Hej Folks.
Just what i Said, just a bit more detailed :D
Great work, Jan,, it is really nice reading with good examples and illustrations. you must have put a lot of effort and time into this
Post by Jan_K »
Hej LJ_krede
Think you should have a look on the wiki.
I am overloading spirit with review doc's.
Special Panel Description and Fixture Creator. :)
