Speed by MIDI?
king_afro
Speed by MIDI?
Post by king_afro »
I Use Freestyler often on difrent Partys...
the most DJ Mixer now have a midi Out and send midi time code
it will be a nice featuer to use MTC for S2L
or not?
FreeStyler Version: N/A
Re: Speed by MIDI?
Post by remco_k »
king_afro wrote: the most DJ Mixer now have a midi Out and send midi time code
Do they? I've never looked for it, never saw it.
Do you have an example mixer brand and model that does? Maybe something like the Pioneer DJM series.
king_afro
Re: Speed by MIDI?
Post by king_afro »
DJM 700, DJM 800, A&H Xone 3d & 4D and Tractor can send MTC via a simpel usb 2 midi device
Re: Speed by MIDI?
Post by remco_k »
king_afro wrote:DJM 700, DJM 800, A&H Xone 3d & 4D and Tractor can send MTC via a simpel usb 2 midi device
Yep, yesterday I looked up the manual of the DJM 800 and it does.
FreeStyler can respond to a Midi trigger with the "Manual trigger" as thats called in the midi setup.
There's also a "Sound To Light" trigger. Is'nt that enough for what you're asking?
Return to “Ideas and Remarks”
