Shutter - ADJ Fixtures Topic is solved
sirwesley
Post by sirwesley »
Seem to be having some problems with the Shutter properties in most of my ADJ Lights.
When I assign Shutter to a FADER (external MIDI Device), Freestyler responds with it as ON or OFF, and no in-between and the shutter value also is used to control strobes. I want to still be able to blackout, when I hit the BLACKOUT button.
Right now I have modified the Profiles to use something such as "IRIS" so that I get full control with the FADER, but this takes away my BLACKOUT functionality.
Any ideas?
-Wesley
Re: Shutter - ADJ Fixtures
Post by LJ_krede.dk »
it works fro me with midi and some futurelight wash lights... Could you upload a fixture you have the problems with, thenn i will try to see if anything is wrong there.. i dont know what else could be the issue.
an idea: could it be the fader on your midi device which send out the wrong values? it has to send out CC values 0-127
