Showtec Clubscan help needed Topic is solved
Soundstar Drive In
Post by Soundstar Drive In »
hello,
Need some help creating fixture file for showtec clubscan 250
Did everything according to manual on this forum, now i have one problem /challenge i don't get.
The scanner has the following DMX channels, can you please tell me how to configure the: rainbow effect, the strobe effect and what to do with the flip gobo options
DMX Protocol Channel 1 - Horizontal movement (Pan) Push the slider up, in order to move the mirror horizontally (PAN). Gradual mirror adjustment from one end of the slider to the other (0-255, 128-center). The mirror can be turned by 180°and stopped at any position you wish.
Channel 2 - Vertical movement (Tilt) Push the slider, up in order to move the mirror vertically (TILT). Gradual mirror adjustment from one end of the slider to the other (0-255, 128-center). The mirror can be turned by 75°and stopped at any position you wish.
Channel 3 –Gobowheel
0-5 Off
6-11 Open / white
12-17 Gobo 1
18-23 Gobo 2
24-29 Gobo 3
30-35 Gobo 4
36-41 Gobo 5
42-47 Gobo 6
48-53 Gobo 7
54-59 Gobo 8
60-65 Gobo Flip 1+2
66-71 Gobo Flip 2+3
72-77 Gobo Flip 3+4
78-83 Gobo Flip 4+5
84-89 Gobo Flip 5+6
90-95 Gobo Flip 6+7
96-101 Gobo Flip 7+8
102-107 Gobo Flip 8+open
108-171 Positive/Negative Rainbow effect with increasing speed
172-251 Strobe effect with increasing speed
252-255 Open
Channel 4 – Dimmer
0-8 Off
9-246 On
247-255 Reset
Thankx in advance.
Dj-Roberto
FreeStyler Version: N/A
Re: Showtec Clubscan help needed
Post by remco_k »
Soundstar Drive In wrote: can you please tell me how to configure the: rainbow effect, the strobe effect and what to do with the flip gobo options
According to the description you fixture has 17 gobo's and:
You need to devide those 2 in steps. Lets assume 4. (but you may do more or less, what fits the best).
Meaning you need to configure 25 (17+4+4) gobos.
The 108-171 should be spread out over that 4 "gobo's".
Same goes for 172-251. Insert nice pictures to explain what it does.
If you have more questions, please post your exported fixture file with it. (*.pff) so we can see were youre at.
Soundstar Drive In
Hey Remco_k,
Thankx, will try to do what you suggestend.
If i'm done shall I post the pff file here?
Mavi
Post by Mavi »
Plese post the file! If you have any further problems we will be able to help you.
If you tested the fixture file and everything works fine post it to the user created fixture files section. So if anyone else want to use the fixture file he can use ures and does not havte to create the same fixture file again.
Soundstar Drive In
oke, I'm finished creating the file, can you tell me how to attach the pff file?
I did not test it jet, since I do not have the interface yet....
If tested it, i will post the file for other forum members.
Also I created all the pictures for the gobo's and the fixture as wel, including the ones for the gobo flipping.
Should I upload them as well, and where should I do this?
Dj-Roberto
Post by remco_k »
In the fixture creator you can export the fixture file you created.
Choose: File->Export.
It will export an *.pff file, that file contains *everything* needed. So you don't need to attach images and other stuff.
Just attach the *.pff file to your post using the upload attachment tab shown under the editor when creating or editing a post.
Soundstar Drive In
Oke, here it is....
Hope it works..
Dj-Roberto
Showtec Clubscan 250.pff
(54.57 KiB) Downloaded 108 times
Soundstar Drive In
Oke finally received the USB Pro dongle.
So tonight will be able to test the fixture file.
Has anyone checked if it was oke?
Thankx.
Dj Roberto
Mavi
Post by Mavi »
I just gabe the ixture file you created a quick look. Everything seams to be fine. Now it is up to you to test with the fixture at your side.
The only thing I noticed you set a lamp on/off channel but no shutter channel. Test the master blackout function. I am not sure if that will work. I think (but do not know exaclty right now if I am right) that blackout will close the shutter. If blackout does not work with your fixture file add values for the shutter channel:
channel: 4, open: 246, close: 0 (or something like that, I guess you know what I mean).
