great software! im in the process of creating a custom midi controller designer for freestyler as i dont think there are any out there
More submasters? Topic is solved
hypnotic_monkey
More submasters?
Is there a way of getting more than 5 submasters? or extra pages of submasters? cheers.
- remco_k
- FreeStyler Version: N/A
Re: More submasters?
Last time I looked there already were multiple pages with submasters?
hypnotic_monkey
Ahh ye scratch the extra pages bit. is there a way of getting 10 subs on 1 page? reason being cos i wana trigger them by keys and it only gives u the option of 1-5.
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
the beta has direct access to all the submaster across the pages.
you can control all 20 submasters without changing pages. however you can only see 5 submasters at the time.
look at the midi and keyboard setting pages in setup.
the feature is in 3.3.2 which is already releasedMattotone wrote:the beta has direct access to all the submaster across the pages.
Version history
hypnotic_monkey
it only has toggle sub 1 to 5LJ_krede.dk wrote: look at the midi and keyboard setting pages in setup.
the sub run 1-20 doesnt work when i assign keyboard controlls
I'm not sure i know what you mean. could you explain what you mean?hypnotic_monkey wrote:it only has toggle sub 1 to 5LJ_krede.dk wrote: look at the midi and keyboard setting pages in setup.
just tested it and you are right... I have reported this to Raph, the developer using the new Freestyler Bug Trackerthe sub run 1-20 doesnt work when i assign keyboard controlls
http://www.freestylersupport.com/bugs/view.php?id=18
hypnotic_monkey
on the assign key page there is something called 'toggle sub' but it only has it for subs 1 to 5 - this turns them on and off and works but sadly only lets you control the 5 of whichever page you are on.LJ_krede.dk wrote:I'm not sure i know what you mean. could you explain what you mean?hypnotic_monkey wrote:it only has toggle sub 1 to 5LJ_krede.dk wrote: look at the midi and keyboard setting pages in setup.
Nice 1LJ_krede.dk wrote:just tested it and you are right... I have reported this to Raph, the developer using the new Freestyler Bug Trackerthe sub run 1-20 doesnt work when i assign keyboard controlls![]()
