ELIMINATOR ELECTRO 196II pff HELP Topic is solved
gta214
Post by gta214 »
Need help creating this fixture i've tried and it somewhatworks but i can't configure the lamp on and off i feel i'm missing something here's what i got so far don't know what to configure next or if any body has it let me know :roll:
Thanks in advance
Link to manual:
http://www.eliminatorlighting.com/pdffi ... 196_ii.pdf
Electro 196II.pff
eliminator
(2.38 KiB) Downloaded 40 times
Reason: 100% of post was uppercase, changed it to lowercase. Please use lowercase the next time.
Re: ELIMINATOR ELECTRO 196II pff HELP
Post by LJ_krede.dk »
Mmax is right..
the Lamp attribute are for fixtures which is not a RGB fixture and have a halogen or discharge bulb you have to turn on before use. That is not necessary when you have a rgb fixture. you rgb par can have a shutter channel, so you have to enter the dmx values there to obtain blackout control over the fixture
FreeStyler Version: N/A
Post by remco_k »
@gta214: 100% of post was uppercase, I changed it to lowercase. Please use lowercase the next time. Looks a lot friendlier for all of us.
gta214
Post by gta214 »
ooo ok now i understand thanks for the help now i can control the cans pretty good with the freestyler thanks :D
gta214
Post by gta214 »
remco_k wrote:@gta214: 100% of post was uppercase, I changed it to lowercase. Please use lowercase the next time. Looks a lot friendlier for all of us.
Sorry It my first posts jijije thanks for corecting it....
Kosh
Post by Kosh »
I have created a Fixture for Eliminator Electro 196 II w/ macros
My problem is, there are multiple channels for the same color and when I select a color lets say RED freestyler only turns on 1 channel of red instead of all 3 channels of red
Chan 1 Control
Chan 2 Red 1
Chan 3 Red 2
Chan 4 Red 3
Chan 5 Green 1
Chan 6 Green 2
Chan 7 Blue 1
Chan 8 Blue 2
http://img169.imageshack.us/i/elctro1.jpg/
http://img220.imageshack.us/i/electro2.jpg/
I looked at some other fixture files with multiple channels for the same color but did not see where it was referenced
Electro 196II.pff
Electro 196 II custom
(37.69 KiB) Downloaded 29 times
Kosh
Post by Kosh »
also, what should i use for the 3d visualizer ?
thanks guys !!
