Hi!
Sorry for my bad english but I will try it.
Normally i would try it by myself to meke this needed fixtures. But time is running through my fingers!! Tomorow we have two new Devices we never used before. The Laser it's a GTECH Showlaser SynthiLase 250 RGY. The only manuel i got is from the same type but 120RGY. Now i hope to control this Laser is on the same way like the stronger one. First problem. Second problem is i find no time to make a fixture for it. I didi it only ones for a LED DEVIL but its a long time ago and I dont realy remember how it works. So could you please be so kind and try to help me out of this situation. Please help me to get this fixtures. I have the DMX Channels but I dont know how to use it.
For the Laser:
Ch 1: Speed/Mode/Reset
Ch 2: Pattern/Gobo
Ch 3: Rotation
cH 4: Zooming
Ch 5: X offset
Ch 6: Y offset
Ch 7: Blanking setting
Ch 8: Color setting
CH 1: 0-200 Scanspeed, 201-254 OperationMode Auto/Music, 255 Reset
CH 2: 0-255 32 basic graphic patterns
CH 3: 0-255 Rotation
CH 4: 0-255 Size
CH 5: 0-255 Offset X
CH 6: 0-255 Offset Y
CH 7: 0 Laser on, 1-254 Blanking setting, 255 Laser of
CH 8: 0-28 Green & Yellow, 28-55 Red, 56-83 Green, 84-111 Green & Yellow 7th channel will be blanking,
112-139 Green Yellow 7th cannel green color blanking, 140-167 Green Yellow 7th channel red colore blanking, 168-255 Green Yellow
Thats the Laser. I hope you can use it.
The Eurolite is a LED MAT-BAR 4x64 RGB
Ch 1: 001-009 off, 010-255 Red
Ch 2: 001-009 off, 010-255 Green
Ch 3: 001-009 off, 010-255 Blue
Ch 4: LED Chaser from left to right
Ch 5: LED Chaser up and down
Ch 6 - Auto Mode/ int. Programm/Soundcontroled: 000-005 No Function, 006-022 Prog 1, 023-039 Prog 2,
040-056 Prog 3, 057-073 Prog 4, 074-090 Prog 5, 091-107 Prog 6, 108-124 Prog 7, 125-141 Prog 8, 142-158 Prog 9, 159-175 Prog 10, 176-192, Prog 11, 193-209 Prog 12, 210-226 Prog 13, 227-249 Prog14, 250-255 Prog15
Ch 7 - Auto Mode Speed: 000-255 increasing Speed.
Please don't try to explain, the only help is to get the finish fixtures at the moment. Off course i'm grateful for any explanation to can understand how to make it by myself but at the moment my head is stuffed off many other things for tomorrow! Thanks for your understanding and also for your assistance.
Kind regards, Wörnsi
Urgent Fixture help need! Laser and Eurolite LED MAT-BAR
Wörnsi
- remco_k
- FreeStyler Version: N/A
Re: Urgent Fixture help need! Laser and Eurolite LED MAT-BAR
If so urgent:
You could have created 2 basic fixture files in less time then you spent on this topic.
1. Create a fixture file of type 'other'
2. Enter the total number of channels
3. If applicable enter the pan and tilt channels
4. On the channel description tab enter the functionality of each channel.
Less then 2 minutes work per fixture file.
leeyow
- FreeStyler Version: 3.4.6
Hallo
I have the same problem witch a same device. (Kam LED Quadbar 1 DMX)
The channel settings are the exactly the same.
Channel DMX value Description
Channel 1 - red colour settings 000 – 010 Off
011 – 255 Red
Channel 2 - green colour settings 000 – 010 Off
011 – 255 Green
Channel 3 - blue colour settings 000 – 010 Off
011 – 255 Blue
Channel 4 - horizontal chaser automatic LED chaser from left to right
Channel 5 - vertical chaser automatic LED chaser from up to down
Channel 6 - Auto mode / progs / mode 000 – 005 No function
006 – 022 Program 1
023 – 039 Program 2
040 – 056 Program 3
057 – 073 Program 4
074 – 090 Program 5
091 – 107 Program 6
108 – 124 Program 7
125 – 141 Program 8
142 – 158 Program 9
159 – 175 Program 10
176 – 192 Program 11
193 – 209 Program 12
210 – 226 Program 13
227 – 249 Program 14
250 – 255 Sound-to-Light mode
Channel 7 - Auto mode speed 000 – 255 Increasing speed
I haveTry t to create a fixture of it but not succeed on it.
Have you mannish to create the fixture? (please would you send it to me?)
Is there someone who can help me on this ? (I would be very pleased)
Kind regards Leo
011 – 255 Red
011 – 255 Green
011 – 255 Blue
006 – 022 Program 1
023 – 039 Program 2
040 – 056 Program 3
057 – 073 Program 4
074 – 090 Program 5
091 – 107 Program 6
108 – 124 Program 7
125 – 141 Program 8
142 – 158 Program 9
Kind regards Leo
- FreeStyler Version: Beta
Hej Leo
Try export the fixture and upload it here then we can have a look on your problem.
