*PAR cans flicker with Velleman VM116 / K8062
CutDMX12
FreeStyler Version: 3.5.2
I Use FreeStyler for: Theater
Post by CutDMX12 »
I don't know if someone still has the installer for FreeStyler before the Output Refresh Rate function was added???
As i have been having a problem with my lighting rig i work with... The problem i am having is with the dimmer racks... when i have the DMX value low e.g. 80 the Par cans flicker.... now after trying to work out why it was doing this, i then found out that it was FreeStyler... as when i tested it with the demo software that came with my DMX unit and had it at the same value... it did not flicker at all!!!
Now i believe it must be since the Output Refresh Rate option has been added, my DMX unit "Velleman k8062 / VM116" hates that new setting... and something don't work and makes the output all made and makes the lamps flicker if you get me??? might be a bug that might need the be fixed at some time.
So to fix this if there's a version that someone has that was out before the Output Refresh Rate function was added that i can try i be very happy to hear...
Thank you if you can help etc... :mrgreen:
CutDMX12,
:fs:
Reason: Topic title changed to something better.
Re: Can someone please help on this?
Because I don't see this very often it may be a problem related to your DMX box which means its not acting the way it should I cannot explain the software part but there are alot of velleman users here that dont have problems... :roll:
FreeStyler Version: N/A
Post by remco_k »
Definately not a FreeStyler problem.
The "Output Refresh Rate" option was always there, "forever" , but was invisible and fixed on 50ms.
Then; "Why the demo works okay?", you say then. That demo does not send out 512 channels but way less - and/or uses just a few channels with values higher than 0 in it.
So here's your test to do with FreeStyler: configure FS to send out 96 channels. (to be found on the interface selection screen).
Add only a few PARs, like 4. Do not add anything else. Make sure all channels send out zero's except those of the 4 pars. My guess is it works correctly now?
Here's the deal: I once owned the VM116 / K8062. That interface has an onboard processor that is just WAY to slow to keep up 512 channels having all different values (and the problems begin at way lesser channels). The interface gets slow, unresponsive and could be the source of your problem. My guess is: it is.
Search on this forum for VM116 / K8062 from me. You'll find loads of posts, seeing me finding out the slow shit.
Solutions:
1. Use lesser DMX channels - or keep as many as possible in a row the same.
2. Learn to live with it ;)
3. Buy a good DMX interface
Re: *PAR cans flicker with Velleman VM116 / K8062
:D
MarSafe
Post by MarSafe »
You're not the only one. Didn't post this problem because I was convinced it had something to do with my dimmerpacks. I'm using ShowTec MultiDims and found out this only occurs if I only had 2 pars connected to a dimmer at a low value. With 4 pars it didn't show. It also could have something to do with the powersupply at the venue. (It was a small place and 4x 525 W was a bit of overkill.... :? )
I'm planning to order an Enntec. If things change for the better I'll let you know.
CutDMX12
Post by CutDMX12 »
remco_k wrote:The "Output Refresh Rate" option was always there, "forever" , but was invisible and fixed on 50ms.
Right can't be that then....
remco_k wrote: So here's your test to do with FreeStyler: configure FS to send out 96 channels. (to be found on the interface selection screen).
Cool, i will try this when I’m back at rehearsals next Wednesday.
remco_k wrote: Search on this forum for VM116 / K8062 from me. You'll find loads of posts, seeing me finding out the slow shit.
Will do... well in fact theres 30 dimmers/lights and there the first 30 channels and only channels at the moe and i have them all on at the same time/same value at some points (exept the ones that had no light pached to... :mrgreen: i can make a list below if you like but i can tell you now that the first 9 are in a row...)
remco_k wrote: Solutions:
Will try it....
remco_k wrote: 2. Learn to live with it ;)
Well we sort of can just means we can have the lights in dim.. only 100% or off....
remco_k wrote: 3. Buy a good DMX interface
Like????
CutDMX12,
:fs:
Enttec USB Pro!!
CutDMX12
Post by CutDMX12 »
djSupport wrote:Enttec USB Pro!!
Ok,
i will have to see if i have the money to get it.... Plus i have to get a 5 Pin to 3 Pin plug...
Other then that i will post back on wednesday to see if the tests worked etc....
CutDMX12,
:fs:
A few months ago I gave a brand new one away for free!
CutDMX12
Post by CutDMX12 »
djSupport wrote:A few months ago I gave a brand new one away for free!
Dam i missed that then lolz
CutDMX12,
:fs:
FreeStyler Version: 4.01
Post by Partyman »
The Enttec Pro will solve all flickering problems! Just set the refresh rate to 10
Rusty
CutDMX12
Post by CutDMX12 »
Partyman wrote:The Enttec Pro will solve all flickering problems! Just set the refresh rate to 10
Rusty
Ok cool,
I am going to to the test today and post the results... if all else fails i will buy one
CutDMX12,
CutDMX12
Post by CutDMX12 »
WORKS!!
Thanks remco_k.... the 96 channels worked.... i just have to be limted to that.... "not like i might need over that with this rig (at the moe :twisted: )"
Thanks again... "just off to play with the Go Monkey Cue... thing... look really cool ^_^ hope to use it in this production..... :mrgreen: "
CutDMX12,
Post by remco_k »
Nice!
That actually proves (again, too bad) that the Velleman VM116/K8062 simply can't keep up when using more channels. Bad equipment... No one should buy that crap anymore. :)
CutDMX12
Post by CutDMX12 »
remco_k wrote:Nice!
Well it was only £50 and i had to put it all together... but hay is a good cheep DMX box that anyone who is just starting out..... plus i have had it for 2 or more years now same as FreeStyler....
When ever I need more Channels i'll get that DMX Pro Box....
Thanks again,
CutDMX12,
:fs:
