Last week, I was buy the Velleman DMX Interface to use on FreeStyler... My problem is... I can't created my fixture in the "Fixture Creator"... The moving head is Triton Blue MiniSpot 250http://www.triton-blue.com/?f=productos ... 250&tema=1 .. Please, I need you help... next week I have one concert and I need use these.
Thanks for all things...
Sorry for my "poor English"... I'm Spanish, and I can't speak English very good...
Triton-blue Spots Topic is solved
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: Triton-blue Spots
Download the manual from the website, at the bottom of the manual page 17 is the dmx table.
Create a new moving head fixture,
Ch1 to Ch6 are straight forward, if not time consuming as freestyler has options for these features.
Ch8 Lamp on Lamp off, freestyler also have an option for this.
Ch7 and Ch8 require you to make macros of you want these functions.
there is a tutorial on macros on this forum.
You will require some kind of imaging tool for the custom gobos, the colours will probably already exist in freestyler
Hope this helps you
Hope this helps you
betadine
hi
im writing from spain (sorry for my english)
im completely new in dmx (absolutely new)
i have a wedding next 2 of june (a friend, & im goping to be de dj)
usually a friend of mines helped me to make all the dmx scenes etc
but this time i want to learn a little bit in order for not to ask her all the time for help
i have 4 moving heads triton blue mini spot sp 250
ive seen that the freestyler doenst have predefined fixtures for that device and i have to make them by my self with de fxt creator
is not possible to create them, make an exportation and reimport them in the freestyler (copyng it into the fixtures folder)
i said that because it seems strange that no one had this fixture
someone has this fxt and could send it to me?¿
or is any other fixture similar that i can use to control it?
thanks a lot
thanks a lot
