13 AUG Gig Pics
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
13 AUG Gig Pics
Bit of a lie, not really any pictures to show you.
turned up at 7:30 to start to set up.
started to setup and asked bar manger if he could switch some lights on so i could see to set up.
he said there may be a small problem with that, they have had a power cut since four. Power company said it should be back on in an hour.
So i continued to set-up by torch light.
8:00 guest arrived - no power
8:30 lights came on.
8:31 lights went off.
bar manager called power company. they have found the fault, it will require digging up the road to lay new cables. power to be expected back on at 12:00
decided to call it a day cut my losses and go home.
The poor ladies party it was, was understandably gutted. certainly one gig i don't wont to repeat again.
Damn Friday 13th
Damn Friday 13th
- djSupport
Re: 13 AUG Gig Pics
jeese how unlucky
- remco_k
- FreeStyler Version: N/A
Re: 13 AUG Gig Pics
Dont you see!? The darkness was a gift from above. Dude! I would have known what I was doing there in the dark.Mattotone wrote: ...ladies party...
I would have called my wife to get me a 'free out of gaol card' and go for it.
- Mattotone
Re: 13 AUG Gig Pics
it looked an awesome crowed...so many fine young women...
- remco_k
Re: 13 AUG Gig Pics
Wait!
I found a really nice picture of women walking around topless screeming for your attention Mattotone:
And you, you are just standing there... Why?
Too bad the pic is so dark because of the darkness. But if you look long enough, you'll see it.
- djSupport
matt
- Admin
- FreeStyler Version: NULL
Re: 13 AUG Gig Pics
You should have went to the local hardware store and rented a Generator!
Matt Hankosky
flickr.com/photos/mattxhank
- Mattotone
Re: 13 AUG Gig Pics
we contacted the local electric company, they said it would take longer to get a genset to us then it would to fix the problem. Theres no where else locally that was open at that time.
matt
- Admin
