I'm looking for a plugin that controls my sunstrips as a vu-meter, i've been searching but didn't find something.
Does anybody have a plugin like this?
Greets, Djreddevil
Suntrix reacting on sound?
- remco_k
- FreeStyler Version: N/A
Re: Suntrix reacting on sound?
There is'nt any.Djreddevil wrote:Hi,
Greets, Djreddevil
I did create a VU-meter -alike several times though.
Used FreeStyler with the S2L 1.0.0.9 plugin.
Created a 4 step sequence. 1st step all on (full VU), 2nd step some from the top off, 3rd step more from the top off, 4th step all off.
Configured the plugin to multilpy the beat 4 times. With Keep on going off. Let it reset the used 'VU-sequence' to step 1 on every beat (S2L's Sequence restarter). Meaning that on every beat all goes on.
Now that is far from a real VU-meter. But it does do a nice trick though.
I used Pixeltracks in this case, so I had actually a red, yellow and green scale.
See also:
http://www.freestylersupport.com/wiki/sound_2_light
Djreddevil
Ok...
Nice solution!
But I can't use it, because I want a multi-band vu-meter.
Nice solution!
