I Need Fixture for Showtec Phantom EHJ-250
Oliver
FreeStyler Version: 2.96G
Post by Oliver »
Hi Guys,
I need a Fixture for my Showtec Phantom EHJ-250
Can some one make me a fixture PLEASE?
I need it very urgend.
The Manual:
http://www.huss-licht-ton.de/pdf/SHTPHA ... 369dae931e
THANKS!
btw, my English is very bad :geek:
Android Dev (Moderator)
FreeStyler Version: BETA
Re: I Need Fixture for Showtec Phantom EHJ-250
Post by Mattotone »
The fixture can be created using the fixture created supplied with freestyler, If you require help with the creation of the fixture please post your problems and we can help you work them out.
The more people we can train to make fixtures, the more fixtures we will have available in the next release of FS for the users.
Matt
Dj_base
FreeStyler Version: 2.96j
Post by Dj_base »
I need it to! please can someone make him,
Also with al gobo's.
I need him very fast PLEASE help us!
Mattotone wrote:The fixture can be created using the fixture created supplied with freestyler, If you require help with the creation of the fixture please post your problems and we can help you work them out.
Matt
as above ^ and for a start the link doesnt work
Scartio
FreeStyler Version: 3.0
Post by Scartio »
I'm also looking for this fixture. I'ld like to use this unit in 16 bit mode (more precise control) but I don't know how to use this.
Channel 1: 16 bit pan
Channel 2: 16 bit tilt
Channel 3: Pan fine 16 bit
Channel 4: Tilt fine 16 bit
Channel 5 Pan/Tilt Speed
Channel 6: Shutter/Dimmer/Strobe
Channel 7: Rotating Gobo's
Channel 8: Colours
Channel 9: Rotating gobo index
- Where to put the "fine" movement controls
- How can you put in Pan/Tilt SPEED in a fixture ? (which is channel 5 in this unit. The manual is at http://www.showfotos.nl/manuals/SHOWTEC ... -250-E.pdf )
- Where to put rotating gobo index ?
I'm new to freestyler....so excuse me if I'm asking stupid questions !
fine pan and tilt you enter the values in the pan 16biut and tilt 16bit gobo rotation index just leave and use sliders on right same with pan and tilt speed.... job done!
Dj_base
Post by Dj_base »
Can you post him or send me to my mail:
DJ_Base@xs4all.nl
Thank you GREETZ! :D
Onge
Post by Onge »
Why don't people have ago a creating their own fixtures. It's not that hard if you have a basic understanding of dmx channels and how fixtures work. If you don't have the basic understanding or not willing to learn then maybe you should look at a new career/hobby.
Have a look at the fixture creator, see what all the parameters are ... if one of the parameters seems correct for your fixture, i.e. the pan/tilt then put in the (dmx) channel address for that parameter. So if pan is on channel 1 put in 1 in the pan field. If Tilt is on channel 2 put 2 in the tilt field.
If it has gobos and/or colour do not base it just on teh physical number of gobos and/or colours, count up how many different settings for that channel you can have and that becomes the number of gobos and/or colours.
If unsure where something goes or what is needed for a particular field then go ahead and ask on this forum we will try our best to help YOU create YOUR fixture.
Also you can just put the channels in the "misc" slots at least you will have some sliders to play with. This is good if you are unsure of all the different settings for a channel, so you can move the slider and hopefully notice what it is doing and make notes as to what the dmx levels for a particular channel does and then enter them in the fixture creator.
When I first got Freestyler 3.0.1 a couple of weeks ago I was creating fixtures within hours of loading the program and when I have sorted them properly (proper gobos and colours, and a tweak here and there) I will upload to the forum.
This is a free program and with free support from everyone on this forum but like life you can't have everything for nothing.
FreeStyler Version: N/A
Post by remco_k »
Spot on Onge. :mrgreen:
Onge
Post by Onge »
Remember if you are creating fixtures in Freestyler they may or not be available in the 3D Visualiser.
If they are not you will have to create them with the ScanLibrary program, this is different to the one in FreeStyler but generally it does the same.
Again I will help people out with this as I have both the Sunlite product and the Daslight product and both use the ScanLibrary program which I am quite proficient with.
mabrev
FreeStyler Version: 3.0.1
Post by mabrev »
This created fixture works perfectly for the EHJ-250:
http://www.freestylersupport.com/fsforu ... wtec#p3499
