Hi, everyone! First post and all that. I would like to know if there is any way to take a screenshot of the render that Magic 3D puts out for showing clients and such.
Thanks!
Matt Noeth
Lighting Designer, Programmer, and Electrician
Matt Noeth Lighting Design
www.mattnoethlightingdesign.com
Magic3D Help!
Doug_Danforth
Re: Magic3D Help!
Shift-Print Scrn will copy your entire screen it to the clipboard. I then usually paste into Power point, crop, then save as image.
mnoethlighting
Re: Magic3D Help!
Cool, thanks! Didn't think to try the print-screen route. Guess I need to think that way more often, as your suggestion worked
Thanks again!
Thanks again!
