Hello Everyone!
I'm new to this site and this program. I only have 3 lights. 2 VEI Novascans and 1 Martin Acrobat. The program let me add my novascans no problem. However, every time I try to add my Martin Acrobat a box pops up saying "Input past end of file" and I have to click ok. What do I need to do to get my acrobat in there?
Thanks in advance for the help!
It won't let me add my Martin Acrobat!!!
- FreeStyler Version: 2.95f
- Bug Zapper...
- FreeStyler Version: 4.1
Re: It won't let me add my Martin Acrobat!!!
Strange, I just tried adding a Martin Acrobat here, works fine. Using version 2.96H, I would suggest you try it and see if it's better.
Warning, if you install over 2.95, you waill have to redefine your fixtures and your interface and the general options are reset, too, but since you only have 3 it will be fast.
Thanks Crrispy, I will try that.
No luck,
It still says the same thing. I can't figure this out.
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
try reinstalling freestyler, you seem to have a fixture which may be corrupt.
Matt
Matt
