Wizard Martin Topic is solved
vinzalex
Wizard Martin
Post by vinzalex »
Good evening all !
I bought 4 wizards from Martin (the fist one not the extreme) and I found in Freestyler the fixture for it but It didn't work at all, so I can't use it.
So I tried to change some values and added some colors.
Could you check it and tell me if everything is ok ! But for some parts I don't know how can I create them.
Please find enclosed the fixture ans the manuel.
I'll be really pleased if I can use it tomorrow (hope) because I have a party.
Thanks by advance !
Vinz
Protocol Wizard.pdf
(72.23 KiB) Downloaded 58 times
Wizard.pff
(73.95 KiB) Downloaded 54 times
