American DJ FUSION FX BAR 2
rayadam
Just started using FS
Post by rayadam »
Please help me with this. In attachment the manual
Android Dev (Moderator)
FreeStyler Version: BETA
Re: American DJ FUSION FX BAR 2
Post by Mattotone »
Freestyler doesn't have all the necessary attributes to make a complete fixture.
Create a simple 16 channel fixture, and label all the channels. You can then use freestylers sliders for each of the RGB channels.
i would also create macros for each of the moon flower functions.
There is detailed instruction in the wiki on how to do this.
hope this helps.
rayadam
Post by rayadam »
Hello,
Thanks for the help. Could you please tell me which fixture what allready is in this system compatible is with this bar
Post by Mattotone »
i don't remember seeing any unfortunately, the best you could do it make the fixture detailed above.
rayadam
Post by rayadam »
I'll try to understand the manual, but thats one with 11 channels. I do really not understand how to do it, because i'm also readblind so thats also difficult.
Which present fixture can I used whats in de list.
