Need Help with a fixture for a Tektonik Laser Topic is solved
bucwheat
Post by bucwheat »
Hi everyone,
I have been trying to create a fixture for a tektonik laser for the past 2 months and seem to be getting nowhere fast with it.
Specs are as follows:
Channel 1 : Control Mode 0-69 shutt off laser
70-139 Auto Mode (music active)
140-209 Auto Mode (Auto Active)
210-255 Manual Mode
Channel 2: Pattern 0-33 Static Pattern
34-255 Dynamic Pattern
Channel 3: Strobe 0-255 8 grade speed (0-255) / 30 = 0-8
Channel 4: Dot and Line 0-69 Normal Display
140-209 Subsection Display
210-255 Dot Display
Channel 5: Horizontal Move 0-60 Manual Move
161-190 Automatic Loop (from left to right)
191-220 Automatic Loop (from right to left)
221-255 Automatic Loop (from right to left and left to right)
Channel 6: Vertical Move 0-60 Manual Move
161-190 Automatic Loop (from down to up)
191-220 Automatic Loof (from up to down)
221-255 Automatic loop (from up to down and down to up)
Channel 7: Zoom 0-2 original size
3-92 manual zoom
93-146 Automatic Loop (from small to big)
147-200 Automatic Loop (from big to small)
201-255 Automatic Loop (from big to small and small to big)
Channel 8: Color 200-255 Green ( laser is only a single color so this is the parameter for my model)
Channel 9: Reset 0-255 The channel value is 200 or greater than the system resets
I would immensely appreciate any help anyone could offer. This is the last fixture I have to get created to complete my show. I am ready to pll my hair out with this one. Many Thanks in advance!!!
Re: Need Help with a fixture for a Tektonik Laser
Post by LJ_krede.dk »
upload the fixture file you have been working on, and explain what you issues are... then we can help you a lot more
