Hi
i am relativaly new to the dmx scene and i dont pretend to know anything but i need the fixture files to a lex moving head led and lanta g50 laser
2 fixtures i could do the fixture files to
Re: 2 fixtures i could do the fixture files to
sorry took so long but here is the manual link http://www.lantalighting.com/assets/han ... ndbook.pdf
- Admin
- FreeStyler Version: NULL
The laser will take time.. what about the moving head..
Matt Hankosky
flickr.com/photos/mattxhank
not even the manufaturer will end me the manuals for that
- FreeStyler Version: Beta
Hej DJ-Twitch.
There is one way to do this but it is a hard way.
Make a fixtur with 16 fader.
Then manually use the fade one by one and see what happens.
It is a bit tricky because some of them can have influence on the other.
Keep the once you don't use in 0 as long as possible.
Record where the changes are.
1 figure out the channal that turns on/ off the beam. It may also set the device to music control.
2 figure out the channals that change patterns. record the patterns eventually take a snapshot of the pattern and use it as icon in the macros. The may be a bank switch fader.
3 Then you have to figure out foom, rotating, strobe, movenents of the figure and of the moving head.
This can take a long time.
It is important that you don't change all faders at the same time because you don't know what happens then.
Also don't expect that the driver runs perfect from the beginning.
You may have to modify it many times.
Hej Again
I just picked up the PC we uses for controlling our lasers.
We have some no name china laser movingheads and I made a fixture the hard way.
You can have a look and use it as insperation.
Think the name is Dortron.
