Virtual RGB led dimmers
reg
Post by reg »
Hi There,
I know its been mentioned before, but one feature that would be a HUGE help in doing what I do (Stage lighting) would be to have a virtual intensity dimmer channel for fixtures with only RGB channels.
This would even be amazing for PAR cans with gels. Ie set a general colour using overrides. THen use cues to bring them bright or lower them down without having to mess about changing colour mixes.
Cheers
Reg
reg
Re: Virtual RGB led dimmers
Post by reg »
Yeah, I was VERY excited when I saw this, however it is only on the master intensity. :(
Reg
Android Dev (Moderator)
FreeStyler Version: BETA
Post by Mattotone »
what i think he is looking for and me too, is a slider in the RGB picker page that acts like a dimmer, by adjusting the RGB values relative to the dimmers slider position.
If this could also be applied to the dmx400 chaser and affect sequences too would be great.
Post by LJ_krede.dk »
Mattotone wrote:what i think he is looking for and me too, is a slider in the RGB picker page that acts like a dimmer, by adjusting the RGB values relative to the dimmers slider position.
I already suggested something similar to Raph last september: a slider to the right and in the lamp settings window to show and adjust the virtual intensity. He told me it was currently impossible. I don't know if anything has changed since then. an alternative is to use a submaster to change the intensity which also has the virtual intensity feature.
Please make a search before posting a new topic. This subject has already been discussed in two other topics. no need for a third one
Virtual Dimmer for LEDs
"Virtual" HTP dimmer channel for RGB fixtures
Return to “Ideas and Remarks”
