Which interface should I get? Topic is solved
spdj20
Post by spdj20 »
I have 2 LED moving heads (11 ch) and 4 par 64 (5 ch). Which interface will be sufficient for this setup?
I see the Enttec Pro is the highest recommended but it's also one of the higher priced interfaces. Would the Enttec Open work well enough? Any other suggestions?
Android Dev (Moderator)
FreeStyler Version: BETA
Re: Which interface should I get?
Post by Mattotone »
iv been using an enttec open on a netbook with a slightly larger rig for a few years with no real probs
dmxlighting
FreeStyler Version: beta
Post by dmxlighting »
Enttec Open device is all good and the Pro device is somewhat better especially if you think you will need to control larger rigs in the future.
There are lots of other good devices avalible.
A better question to ask is ' what device should I stay away from?' the answer to that would be any really cheap one's or selfbuild kits.
Return to “DMX Interfaces”
