"Subscript Out of Range" Topic is solved
skip1
Post by skip1 »
hi again,
I get an error message saying "subscript out of range when trying to create a sequence.
What does this mean?
Re: "Subscript Out of Range"
Post by LJ_krede.dk »
looks like a bug.. can you give some more detalis what you did before you got this error? does it happen every time?
skip1
Post by skip1 »
yes it happens everytime. i am running windows 7 and am in need to use this program tonight.
is there any way i can get it working by then
you can try to remove FS and install it again.
if you still have the problem try to install another version
you should report the problem to the developer:
[bugreporting][/bugreporting]
FreeStyler Version: N/A
Post by remco_k »
skip1 wrote:yes it happens everytime. i am running windows 7 and am in need to use this program tonight.
Tell us exactly what you do, what buttons you press before you get the error.
Also tell us the exact error. And the exact point when this occurs.
So as an example: you start FreeStyler, open the sequence window by clicking on the icon in the menu, ...
You fill it in. Completely!
algoes
FreeStyler Version: 4.0
Post by algoes »
Hello i have the same problem in version 4.0
FreeStyler Version: 4.01
Post by Partyman »
Subscript out of range usually happens when people have created fixture files on one machine and copied the folder rather than export them. When you export fixture files it includes all the pictures, icons, and gobos associated with that fixture. When you just copy freestyler folders is does not install the fixture profiles correctly and gives the subscript error. You will also get that error.
You will also get this error if you have renamed any override buttons, sequence button, ... that is used in a cuelist, submaster, override, ...
Poytoy
FreeStyler Version: 3.71
Post by Poytoy »
@Partyman Thanks so much. That problem was driving me nuts too.
lj_raph
FreeStyler Developer
FreeStyler Version: 3.2.1
Post by lj_raph »
Hi, if you encounter this error post it in the bugtracker with the exact steps to replicate it and if possible include your backup file. This message can appear everywhere and mostly in case of a bug or a problem with the fixture file.
In version 4.0.1 you will encounter this messgae in the cuelist playback window, this will be fixed in version 4.1.
If you encounter it elsewhere let me know where.
Raphaël
halfbright
I Use FreeStyler for: Theater
Post by halfbright »
Hi, has the issue of "Subscript out of range" been resolved?
I just got a new system & I have installed the newest version that is offered. (running windows 10). When I try to create a cue or a chase, it does not save the dimmer value. When I bring up the cue list window, the subscript message appears. If I close the program the next time I open it, the subscript message appears during the boot up cycle & locks up the program that I have to reboot the system. It stay that way until I reinstall the program with the restore defaults check.
Is this a new wrinkle to the problem?
Crrispy
Bug Zapper...
FreeStyler Version: 4.1
Post by Crrispy »
I get this error too, when dragging a sequence on a cue. Only does it with 1 sequence, I'll just redo it. 4.x still needs some fixing :-)
halfbright wrote: 27 Jun 2021, 19:07 Hi, has the issue of "Subscript out of range" been resolved?
If you havent already please make sure you all report these bugs on the bug tracker!
