Regards Frankie.
Can any one help me out with a contest 930 Topic is solved
Frankiewizard
Hello out there in the bright and colorful world of FreeSyler. I have been using freestyler on some show tec fixtures and it works well. But with the contest 930 which are not in the fixture lib I have indeed tired creating in the fixture creator. Putting there configuration in but to no avail; I know that it is not difficult to do but I don't seem to be doing the right thing can anyone help me out ? There are just six channels on the fixture.
Regards Frankie.
Regards Frankie.
vinzalex
Re: Can any one help me out with a contest 930
Hi Frankie,
Have you created or received the right fixture for SCN930 ?
I also have 2 scn930 and I'd like it please.
Vinz
Vinz
vinzalex
Hi One,
Please find enclosed what I've created (included the manual).
I've created the first canal for color, the second canal for gobos (missing just the shake gobos), the 3th and 4th for movement, I hope that is well done !
But for The 5th about Reset, Program I've no idea !
Thanks for your helping !
Vinz
Vinz
vinzalex
Good afternoon,
Does someone have any news about my fixture for scn930 ?
I'm trying to change the picture (I'd like to write "shake" on some of them) to finish the second canal.
So, If someone could help mefor the 5th Canal and "Shutter ch., open, closed, Strobe ch., off, low, high", I'll be really
Thanks.
Vinz
Thanks.
Vinz
vinzalex
For the manual, you'll find enclosed a file scn930.zip
Inside, you have the manual, ok it's in french (I'm sorry), but at the page 10 you can find all informations about channels.
So, could you help me with it ?
Thanks a lot.
Vinz
Thanks a lot.
Vinz
vinzalex
Hi Onge,
Thanks a lot for your help.
I'm sure, it'll be ok
I can help you or I can try to do the shake gobos, because that the same gobos (15 fixed gobos and 15 shake gobos same than fixed gobos).
So I can tell you the order of the shake gobos if you want, I've tried to write "shake" on the fixed gobos without success. I'll try tonight or this week-end.
But first of all, I'm trying tonight the fixture modified.
Thanks.
Vinz
Thanks.
Vinz
vinzalex
Hi Onge,
I have added the 15 shake gobos and I changed the value for the color wheel.
I also created the 3 different speeds (clockwise and ant-clockwise).
I've tested all parameters today, and everything seems alright.
So please find enclosed the scn930's fixture.
(I'm sorry if you find some mistakes in me English because of the fact that I'm french and I'm learning English).
Thanks again.
Tomorrow, I'll begin creating fixture for 2 differents Moving head (but I've no manual
I must find all parameters with my controller (a bit more complicated 16 canals)
Bye
Thanks again.
Bye
scn 930.pff- (153.81 KiB) Downloaded 52 times
zeubest
I've made this one for me, hope it can be of some use.
Voilà ma version , j'espère qu'elle sera utile.
http://zeubest.free.fr/scn930.zip
