In freestyler can i for example put all the colors in shorcuts?
i mean 1 will stand for white
2 will stand for yellow.........
3 for blue....
i saw on the shorcuts that there is only next and previous color and there isnt shorcut for everycolor....
About Shorcuts Topic is solved
- remco_k
- FreeStyler Version: N/A
Re: About Shorcuts
Have a look at the override buttons. You can program a one step sequence in it, setting alle the colors to whatever you like.
A really quick tutorial:
1. Open the sequence editor, select the fixtures you want to make red, make them red
2. Save the sequence, give it a name: "all red", select the "Add to buttons" checkbox.
3. Do step 1 and 2 for all colors you like (green, blue, yellow,...)
4. Close the sequence editor, open the override buttons window
5. Press the buttons.
More can be found in the help file or on the wiki page.
