Big Problem with cues
DJKoby
FreeStyler Version: 2.912
Post by DJKoby »
Please helb me !
I made cues one for my Par Cans, one for my scanner, One for MHs etc, Cue Multiselect in the extra options is enabled ! If i run two scenes the first one stopps !
Its like cue multiselect is disables ! Where is the mistake !???
Please help me !
FreeStyler Version: N/A
Re: Big Problem with cues
Post by remco_k »
DJKoby wrote:Please helb me !
Please help me !
I assume the cue button still shows that its playing and steps (X/Y) are still running (on screen - but no DMX output) for the cue that -seemed- to stopped?
If Yes: then you have programmed the second scene incorrectly, it most probably controls DMX addresses that are also controlled by the first scene. Since the cue works LTP, thats obvious the way it should work. You need to fix your scene and set those "wrong" channels to "off", that will fix your problem.
If No: Then multiselect isn't enabled. :)
I guess its the Yes, so you should review your second scene for controlling DMX channels/fixtures that it should not. Also restarting (stop/start) the first cue would make that scene active again. (Like its meant in LTP)
I believe that when you edit a scene an * occurs at fixtures that are controlled by that scene. So if you're editing the scene of your par cans, only at the par cans should that * be visible. Not at any of the other fixtures. The same is the other way around when editing a scene for your MH's.
So in short: if you program a scene for fixture A, B and C, then all DMX channels for D, E and F should be set to 'OFF'. Unless you want it to control those channels...
Btw, asking your question with lots of !??? and ! in it doesn't speed things up. :)
