During Install, Sunlite Magic 3D Easy View Doesn't Download Topic is solved
andrewjwatts
Post by andrewjwatts »
During an install of version 3.1.1, I select the option "Download & Install Sunlite Magic 3D Easy View", and after letting it through my firewall its happily downloads, but when it reaches 99% the download times out and fails.
Any help?
dmxlighting
FreeStyler Version: beta
Re: During Install, Sunlite Magic 3D Easy View Doesn't Downl
Post by dmxlighting »
Thats a little odd. Can you try to download to a different pc?
As far as I am aware there are not reported issues with any of the downloads.
rrlighting
Post by rrlighting »
i have the same problem too...
it keep saying time out...
Post by LJ_krede.dk »
nothing to do with freestyler.. However download the Magic 3D Easy View manually and install it in the freestyler folder
now, you should be able to run easy view from FS
Magic 3D Easy View page
