Problem with Override Buttons Topic is solved
DJKoby
Post by DJKoby »
Hello I have a Problem !
I made scenes in in Cues with Scanner an MH´s and everything is working ! In the override Buttons i have my strobes and Colorlabs with only one thing. Now if a Cue is running and i Press a override button disables everything else . Only the scene in the button is active ! Is it possible to run both ??
The Second problem is with the Multicue ! in the setting Multicue is enabled but only one cue is running ! I can klick the Play button and the scene starts but the lamps dont run
thanks for you held Greets
dmxlighting
FreeStyler Version: beta
Re: Problem with Override Buttons
Post by dmxlighting »
DJKoby wrote:I made scenes in in Cues with Scanner an MH´s and everything is working ! In the override Buttons i have my strobes and Colorlabs with only one thing. Now if a Cue is running and i Press a override button disables everything else.
Yeah they will do that, that why they are called 'Overide Buttons' as the will overide everything thats running.
As for the other problem with multicues, can I recommend that you look at using submasters. There is a really good tutorial on how to use them of the FS wiki or http://www.freestylersupport.com/fsforu ... f=5&t=1803
