Frabriquer un cable USB/DMX
Je recherche un shema pour monter un cable usb dmx auriez vous ca en stock merci d'avance
- remco_k
- FreeStyler Version: N/A
Re: Frabriquer un cable USB/DMX
It would be easier to ask your question in english.
I understand you want to build a DMX interface yourself? Here you go, based on the Enttec open dmx: http://gathering.tweakers.net/forum/lis ... s/1342011/
Large
Are you looking for a 'construction box' having all the parts and casing or do you really want to build it yourself from scratch?
In case of that last one: you might need to be able to program a little PIC controller or CPU. Are you?
By the way: If you think its cheaper to build it yourself (from scratch) you'll probably be dissapointed in the end... Depending on various things.
Large
