Chauvet Intimidator Scan LED Topic is solved
highvoltageboston
Post by highvoltageboston »
Are there files available for the Chauvet Intimidator Scan LED?
Tascam
Re: Chauvet Intimidator Scan LED
Post by Tascam »
Anyone? Specifically the Intimidator Scan 200 LED. Thanks in advance for your help!
Tascam
Post by Tascam »
Anyone? Can I pay someone for a profile please?
Can I also pay someone for a profile for a Venue ThinPAR 64?
Thanks.
dmxlighting
FreeStyler Version: beta
Post by dmxlighting »
Just have a go yourself. Post what you have done and if you need help finishing it then someone will.
There are tutorials on hoe to do it so read them and try it. Its not hard to do if u have the product info sheet.
I can build profiles for most things with out an info sheet. Just get a pen and pan and make notes.
