vitual finger for freestyler
Jaykie
FreeStyler Version: 3.01
Twitter: http://twitter.com/jaykie
Post by Jaykie »
This is from the old forum
Kindlefire
is there any products that can be integrated into freestyler that work link the martin light jockey's virtual fingers?
Honslow
Tjeck out the forum about the Behringer BCF-2000 midi control. Thi control can be used with freestyler, much like Martin fingers.
Skylight
I think kindlefire doesn't mean a realtime midi-controller, butt a virtual-one. This would mean an extra window with "faders and buttons" assignable to all the functions in Freestyler (just like midi controls and the BCF2000).
It would be a nice feature, just not sure if it really would add something extra to Freestyler, by opening the submasters and override buttons you practically already have all the on-screen controll you need.
(Unless you want the special functions like macro Speed, macro size etc... These functions aren't available in Freestyler, at all. The beziers don't work the same way they do in LightJockey)
there are a few virtual midi control software, where you can make your own virtual desktop, then use it to control freestyler.
