Microh Virus 30 & DuoBeam MKII Lasers
jonny b good
Post by jonny b good »
Here is a fixture profile for the Microh Virus 30 Laser and can also be used for the Microh DuoBeam MKII Laser as well.
Untested as I do not have these fixtures, I am sure I have mad one of these before but cannot seem to find it anywhere, strange.
Needs all the images for the patterns, macros etc. sorting out as I have just used what is available and most are not correct.
Use the Macros to set the Mode.
The "1" in macros sets the predefined patterns on Gobo Wheel 1 (Channel 2), cannot use channels 3-8
The "2" in macros sets the mode to single picture mode, choose with Gobo Wheel 2 (Channel 3), and then adjust, with gobo rotation (Channel 5), zoom (channel 4) move on the X/Y axis using the Pan/Tilt (channels 6 & 7) (does not work same as a scanner or MH though), and speed on the Focus control (channel 8). Cannot use channel 2.
The other modes speak for themselves.
EDIT:- Forgot to say I added a shutter values so you can use the "Blackout" button within FreeStyler and it will turn of the laser.
Play around and find what works for you.
Hope it helps,
Microh Virus30 Laser.pff
(195.11 KiB) Downloaded 46 times
jonny b good
Re: Microh Virus 30 & DuoBeam MKII Lasers
I thought it looked familiar, it has the same DMX channels and values as the Ibiza Light Laser 100-R
See this post for another version of the fixture, very similar and actually created by the same person ... hee hee hee
