Submaster
Blasterstef
FreeStyler Version: 3.3.1
I Use FreeStyler for: Theater
Submaster
Post by Blasterstef »
Hello all,
I have developped myself my usb dmx interface, and I start to discover FS.
I have created a small show with only 4 PAR 64, and created a simple sequence, add it in cue, and add the cue in submaster.
When I change the submaster only the first PAR is impacted ...
If some one can explain me ... I can send the location for debug.
Rgds
Stef
jonny b good
FreeStyler Version: 3.3.2
Re: Submaster
Post by jonny b good »
I take it you have read the submaster tutorial in the FreeStyler Wiki if not then do so as it might resolve your issue.
Android Dev (Moderator)
FreeStyler Version: BETA
Re: Submaster
Post by Mattotone »
Does the sequence work correctly in the cue window?
Care to expand? Im guessing only the first par can is "Working".
You may also want to reed the about the sequence editor in the WIKI
Blasterstef
Re: Submaster
Hello,
I have already read these wiki items.
The sequence works fine in the cue window.
With the submaster window I'm able to start and stop the sequence, and the sequence work fine too.
My problem is only regarding the lamp intensity. I'm able to have the dimmer only on the first Par of the sequence, the others are at 100% ...
The master dimmer works fine on all PAR
I hope it's more clear now.
Rgds
Stef
Reason: double post deleted
Re: Submaster
Post by Mattotone »
ahhh. there is a bug with the sub-master. this has been fixed in the latest beta.
Hopefully the beta will be released soon for the rest of the board.
kdiamond
Re: Submaster
Post by kdiamond »
Aaaargh. I've been struggling with it for more than hour, thinking what am I doing wrong !! :)
I hope we get an update soon
:fs:
Br,
kd
