Weird problem?!?
Crrispy
Bug Zapper...
FreeStyler Version: 4.1
Weird problem?!?
Post by Crrispy »
OK, added the 4 moving heads (I uploaded the fixture file 1 hour ago).
Started playing around fine.
All of a sudden, no way to open any properties window when one or more is selected, either through the menu, the "show all panels" button or the individual buttons.
OK, let's close-reopen FS (solves most often weird behaviors..)
BAD LUCK, same problem :-( :(
Any idea?
Thanks.
Android Dev (Moderator)
FreeStyler Version: BETA
Re: Weird problem wtf ?!?
Post by Mattotone »
for all fixtures or just the heads
Crrispy
Bug Zapper...
Re: Weird problem?!?
Post by Crrispy »
For all fixtures. Just solved, I went through all of the menus/screens of FS until I found it had created some weird groups I never asked for, including seemingly random fixtures several times in some groups. I never used groups up to now and never went to the groups screen.
Bugstyler :?
Crrispy
Bug Zapper...
Post by Crrispy »
Update: problem had nothing to do with the unwanted groups... it's back! :-(
Update 2: by clicking several times on the fixture, the show all panels button, (I mean really several times), it finally re-appears... hope I don't get this during the party tomorrow...
Crrispy
Bug Zapper...
Post by Crrispy »
Updated to 2.96H, same problem, happens randomly. When it happens, I click on the fixture(s) and on the "show all" button until it finally appears. Can take from 5-6 to a dozen clicks..
either your looking hard for bugs or everyone else never has your problems....
Post by Mattotone »
Crrispy wrote:For all fixtures. Just solved, I went through all of the menus/screens of FS until I found it had created some weird groups I never asked for, including seemingly random fixtures several times in some groups. I never used groups up to now and never went to the groups screen.
Bugstyler :?
Freestyler automatically creates groups as you add fixtures, that can be disable on the fixture setup screen.
As for your problem its a very strange problem, iv used many freestyler versions on many machines with many different fixtures
and never seen anything like your bug, and iv experienced lots of bugs.
Could you make a backup and upload this could be a config error, fixture error or maybe even user error.
Kind regards
Matt
Crrispy
Bug Zapper...
Post by Crrispy »
Bugstyler :?
Kind regards
Matt
Yes, where do I have to upload it? In this thread? Note that I used FS for a party on saturday and I had the same problem on the notebook I used.
Post by Mattotone »
btw
Are the buttons disabled?
are you selecting multiple types of fixtures? Freestyler only enables the buttons for the last fixture type selected.
Are your last fixtures a dimmer pack? fogger? these don't have panels so wouldn't open any window.
a screen shot of your desktop would be nice , with exact steps starting from when you open freestyler (every button press, menu opend etc.) so that we can trace your steps.
Post by Mattotone »
just upload it to this thread the option is bellow the writing pane when you create a post.
Crrispy
Bug Zapper...
Post by Crrispy »
Mattotone wrote:btw
No, when it happens I only select one or two moving heads, or one or two scanners. When it starts doing this I click like crazy on the fixtures and the show all panels button and it finally shows the panels.. ( I mean pan/tilt, color, gobo panels etc.)
Crrispy.zip
zipped backup file
(75.09 KiB) Downloaded 58 times
there is screen recording software outthere for free off sourcefourge you could record you actions!
Crrispy
Bug Zapper...
Post by Crrispy »
DJ Support wrote:there is screen recording software outthere for free off sourcefourge you could record you actions!
I was thinking about this about 1 minute before you wrote it :-) Will do this as soon as I have time to. Could also show the bezier mess up.
Post by Mattotone »
can not replicate your bugs, tried everything i can think of and no problems.
Have you ever run a second screen? Or dragged your panels of the screen?
Crrispy
Bug Zapper...
Post by Crrispy »
Mattotone wrote:can not replicate your bugs, tried everything i can think of and no problems.
No single screen both on the PC and on the laptop.
PC running XP SP2 french, laptop running XP SP2 english.
you should do remote assistance so we can see your desktop add me to wlm using buttons on right then i'll see what ur doing!
Crrispy
Bug Zapper...
Post by Crrispy »
Like I said in the other thread, reinstalled everything from scratch, still the same problem, too. Could it be a problem with my fixture files?
Post by Mattotone »
matt wrote:you might try to re-install your .net framework
Crrispy
Bug Zapper...
Post by Crrispy »
OK, I can try this, which version does it use? 1.1, 2.0 or 3.0 ?
Also where can i find the install files, I installed them with windows update.
Thanks.
Post by Mattotone »
http://go.microsoft.com/fwlink/?linkid=70848
Should automatically repair or upgrade.
Crrispy
Bug Zapper...
Post by Crrispy »
Mattotone wrote:http://go.microsoft.com/fwlink/?linkid=70848
Did this. No change :cry:
Post by Mattotone »
Could you make a video, you seem to have a very strange and unique problem.
Crrispy
Bug Zapper...
Post by Crrispy »
Yess, will try to install a tool for this tomorrow.
or add me to msn messenger and i'll do a remote assistance then you can show me this problem LIVE
